Unknown Base Plugin Nub Error
2,024 次查看
tcherno
hello,
I have a project in Code Warrior 10.6.4 IDE developed for MC9S08QE128 MCU.
I am using PE micro Multilink FX as a debugger and programmer.
until a week ago I was able to debug and burn the code. to the flash of the MCU with no problem.
now when i try to debug or burn the code i get the error "Unknown Base Plugin Nub error".
with the PROGHCS08 - Flash Programmer Software from PE micro i have no problem burning the code on the board with the same debugger.
when checking the signal of the BDM, i can see that the PC tried to initiate connection with the MCU.
have anyone faced this problem and can help me?
thank you,
omer
0 回复数
