Unable to communicate with S08 when FLASH erased
1,356 次查看
aruraghuwanshi
I'm using the debug port of S08 to program it via an external controller. I've noticed that the S08 responds to these pulses via the BKGD PIN only when the FLASH memory is NOT ERASED. I was wondering why this was happening ?
1,245 次查看
vicentegomez
I got lost
Would be possible that you explain a little bit?
Vicente Gomez
