Timer Callback problem - MC1321X
3,503 次查看
bitasobhani
Hi all
I am working on Mc1321x.
I want to insert a dalay of for example 10 seconds inside the code. I did it as below:
#define mDelayTime_c     TmrSeconds(10)
TimeFlag=0;
TMR_StartSingleShotTimer(DelayTimerId,mDelayTime_c,DelayTimerCallBack);
while(TimeFlag==0){}
TimeFlag=0;
void DelayTimerCallBack
  tmrTimerID_t  timerId
  (void) timerId;
  TimeFlag=1;
All variables are defined as global.
But this code does not work. The problem is that the while loop does not permit timer callback to occur.
what should I do.
Thanks a lot
Added p/n to subject.
Message Edited by NLFSJ on 2008-10-29 09:43 AM
4 回复数
2,349 次查看
Spell
Hi bitasobhani,
you must allocate the DelayTimerId timer before you can use it.
DelayTimerId = TMR_AllocateTimer();
regards,
filippo
2,349 次查看
bitasobhani
Thanks for reply
No I didn't forget to allocate timer.
2,349 次查看
Lundin
Senior Contributor IV
To me it sounds like you forgot to make the variable volatile.
2,349 次查看
bitasobhani
Thanks for reply
Can you please expail what is volatile and how can I do this?
