The programming for the PT MCU
1,591件の閲覧回数
shuchengzhu
I am now using a MC9S08PT60. I could not find a method to proeSgram the chip on the PCB. I tried the UBDM and it does not work. Is there any other programming method??
Shucheng Zhu
1,437件の閲覧回数
david_diaz
What do you mean with “proeSgram”?
If you are trying to program the MC9S08PT60 on the PCB, you can use the Open Source BDM Module supported by P&E due to the TWR-S08PT60 counts with this module.
http://www.pemicro.com/support/index.cfm
Because it is open source, the source code can be used and/or modified from its original design free of charge.
Please find more information about the OSBDM in the User Guide, Chapter 1, from the next link:
http://www.freescale.com/files/soft_dev_tools/doc/user_guide/OSBDMTAPUG.pdf
Hope this information will be useful for you.
