TDA1301T - Serial Protocol Documentation
ogarvey
Hi there,
I'm currently attempting to investigate the communication between a TDA1301T and other components in an old Philips CD-i player and was wondering if there was any documentation available for the serial protocol?
The datasheet says the info is available on request, but I'm aware it's an old datasheet, so was hoping someone might already have and be able to share the info.
Any guidance appreciated.
Cheers all
carlos_o
Hi @ogarvey
Thank you for your post.
The IC you mention is obsolete and the documentation regarding it has been purge.
An apology for the inconvenience this might cause you.
