Setting 115200baud on QE128 using internal oscillator
1,920 次查看
abhijit_78
I need to set 115200bps on my QE128 board using internal oscillator. I am using processor expert to generate the code and have set internal oscillator freq to 36KHZ to get a bus clock of 9.216MHZ which can then easilty generate the required baud rate of 115200.
However, the actual bus clock that i get is 8.35MHZ and hence the baud rate is also not correct.
Pls suggest.
Thanks.
982 次查看
ProcessorExpert
Senior Contributor III
Your problem has been solved here:
http://forums.freescale.com/freescale/board/message?board.id=CFCOMM&message.id=4376#M4376
best regards
Vojtech Filip
Processor Expert Support Team UNIS
www.processorexpert.com
982 次查看
abhijit_78
Thanks for the information.
I am now able to communicate at 115200baud.
