S9S08QD4
2,024 次查看
kumari
Hi ,
i purchase the S9S08QD4 IC for my project. May i know which software and programmer is best for that particular controller and also the basic working circuit with programming.
2,010 次查看
vicentegomez
for debug and program you can use
https://www.nxp.com/products/power-management/motor-and-solenoid-drivers/powertrain-and-engine-contr...
or you can create your using the OSBDM
https://www.pemicro.com/osbdm/
I hope this will help you
5 回复数
1,975 次查看
kumari
Thanks for your reply
2,007 次查看
kumari
Thanks for your reply. which compiler can i use for this controller?
1,998 次查看
vicentegomez
1,987 次查看
kumari
2,011 次查看
vicentegomez
