S08 SCI Transmit Issue
gregoryberardi
The attached code is what I'm using to try to send data out the sci tx port. The problem I am having is that I'm not seeing anything on the output (PTA3).
Any help is appreciated. Thank you in advance.
Original Attachment has been moved to: main.c.txt.zip
Tags (3)
ZhangJennie
can you please check this thread? i think it should help you: https://community.freescale.com/message/330916#330916
ZhangJennie
gregoryberardi
Yes, I did try the code. After changing the SCI2s to SCI0s I was unable to get it to work either. I noticed that there was a read of SCI0_S1 (which clears the flags) just before the while that waits for the flag to clear in the example that you linked. I put that in my code and it appears to work.
Thank you!
