S08 Calculating TPM bit resolution when used in PWM mode?
2,079 次查看
iansmusical
Hello Everyone,
Does anyone know how to calculate the TPM bit resolution when used in edge PWM mode please? For example, if I use a bus clock of 4MHz, a prescaler of 2 to generate a 120Hz period, I calculate TPMxMOD to be 16667 but how do I calculate the bit resolution of the PWM output?
Thanks in advance,
Ian
标记 (3)
1,819 次查看
kef2
Senior Contributor V
ln(16667)/ln(2) = 14.02
1,820 次查看
kef2
1,819 次查看
iansmusical
Hi Edward,
Thank you for your answer, very helpful.
Ian
