Reset when the log () function is executed;
agarcia
I am working with the MC9S08PT16VWJ microcontroller when I execute the following instruction:
b = (float) log ((double) c);
A reset occurs on my card when the value of c is greater than 150, I have wachDog disabled.
What I can do?
kef2
Senior Contributor V
Floating point support requires more stack space. Try increasing STACKSIZE in PRM file.
kef2
agarcia
yes, it already worked by default it has 80H increases it to 100H and it worked correctly
vicentegomez
Can you please check the SYS_SRS register
I am thinking that you are running out of memory
Have a good day
