RS08KA4 I/O status when it's power down? KA4 i/o current up to 30mA when connected to 3.3V.
1,360 次查看
w_tension
I shut down mcu(KA4), and a power-on trigger circuit is working.
But it even consumes more current.
Then I  found that it's i/o is not high-impedance. Why?
标记 (1)
1,075 次查看
w_tension
I changed the method to shutdown the MCU, just keep it under reset.(Workaround)
1,076 次查看
w_tension
