RS08KA - Read Values in Non Volatile memory
1,543 次查看
SecondTechCo
I want to read byte values from the Flash memory.   My understanding is the code is simple.  I am trying to do this in C .  It looks like I set a value in PAGESEL and then read memory. I dont see a define anywhere that lets me read the byte.  So the code would be :
unsigned char Temp;
PAGESEL=0x80;
Temp = ?;
1,438 次查看
arpitaagarwal-b
You can read the value directly from the address as shown below:
       value = *(unsigned char*)0x0080U;  //memory location you want to read is assumed as 0x80 here
Arpita
