ROM-Resident Routine PUTBYTE
5,143件の閲覧回数
Brusse
Is it possible to use then ROM-Resident Routine PUTBYTE in a 68HC908QT4 (Classic). I found the routine in the new improved 68HC908QT4A but can´t find any documentation about Classic.
4 返答(返信)
2,321件の閲覧回数
bigmac
Specialist III
Hello Brusse,
The PUTBYTE  routine should be located at address $FED0 for the QT4 (classic).
Mac
2,321件の閲覧回数
Brusse
Many thanks, Mac
Do you know if there is any special conciderations to deal with before i make a call to the routine, i guess the charater to be send should be held in Acc. (have you found this information in some docs?)
2,321件の閲覧回数
bigmac
Specialist III
Hello Bru,
Have a look at AN1831 (Rev 3), where the code for the ROM routine RDVRRNG makes a call to PUTBYTE.  I think I have also read that the H:X register value is preserved by PUTBYTE.
I have not yet done so myself, but it may not be too onorous to disassemble this code, using an actual device, to find out how the routine works.
Mac
2,321件の閲覧回数
gbm
Yes, it is possible. The built in monitor code uses it.
