Programming MC9S08PA
1,507 次查看
weab
We are a small company that has a customer that is using the MC9S08PA60VLD in one of his new products, There is an ISP connector on the PCB, what hardware and software do we need to program this?
1,499 次查看
vicentegomez
Normally the S08 has BDM interface for program and debug them. (BKGD, Reset, VDD and GND pins).
If the connector is for this pins that you can use the P&E multilink
http://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320143&productTab=1
But if the customer is using a bootloader you need to check the communication module that they are using like UART, SPI or IIC
I hope this will help you
Have a good day.
