Problem in SCI Module
1,732件の閲覧回数
lipsa
I am not able to use SCI2D(Data register)  as it is not getting initialised.can u please let me know how to initialise the same so that i can use it further in my code
998件の閲覧回数
bigmac
Specialist III
I am not quite sure what you mean when you refer to "initialising" the data register of the SCI.  This register is used specifically for sending and receiving each data byte.  When you write to the register, the value written will be sent by the SCI.  However, a read will get the last byte received by the SCI.
Mac
