Printing Messages in Full Chip Simulation with MC9S08JM60
2,044 次查看
LuisJZB
Hello, I'm running a full chip simulation on MC9S08JM60 MCU, I was trying to find any information to see if it's possible to have a "Simulated LCD" or terminal where I can print messages out from the MCU, as I would do it in a real life situation.
This is my SW version
Installed Products:
- CodeWarrior for MCU
Version: 11.1
Build Id:181224
Thank you very much.
2,028 次查看
vicentegomez
I have not used all the chip simulator function but please check the section
9.1 P&E Full Chip Simulation of the document
Targeting_microcontrollers.pdf
you can find this document on the codewarrior folder
normally
C:\Freescale\CW MCU v11.1\MCU\Help\PDF
I hope this will help you.
