Is it possible to copy the contents of one controller to another
2,040 次查看
matrixmm
Hi, sorry for the stupid question.
Is it possible to copy the contents of one controller to another.
I have the same two boards. One is working and second broken. I repaired the second board and replace burned HCS08 controler with new one.
The question is, can I somehow copy the content from a working controller to a clean one?
using USBDM for example?
any help will be appreciated
3 回复数
1,991 次查看
matrixmm
I solved. If someone has a similar problem, it can be easily done using USBDM Memory dump. Rip flash to a file and upload with FlashProgrammer to a new chip.
2,025 次查看
vicentegomez
If the original firmware is not protected, yes you can perform an "attach" on CodeWarrior using the multilink.
1,998 次查看
matrixmm
I try program one chip and clone to another. Just for learning.
It's not protected. In codewarrior i choose MAC Tools -> Attach to target. But not have USBD programmer to choose. :(. Whats i do wrong?
Any help will be apreciated.
