PWM with device initialization
1,947件の閲覧回数
Juls
Hi im using a MC9s08QE32
I want to have a constant pwm
So in device initialization I set the right timer and channel for the pin im using
Set it to edge aligned
Set modulo to 99 and compare value to 50 for now
and set output on compare
but the thing doesnt seem to work
I must use ovf interruption to clear the pin??
and another thing is how do i increase or decrease the pwm
simply writing c0vl and c0vh at any moment?
1,165件の閲覧回数
ProcessorExpert
Senior Contributor III
settings on attached screenshot should help you to solve your problem.
best regards
Vojtech Filip
Processor Expert Support Team
