No CPU Selected Codewarrior 10.1
2,652 次查看
slanfys
Hello!
I'm working with this codewarrior IDE. When I start a project and  I select my MPU I can work with Device Initialization in a window called Target CPU. Once I quit IDE and come back, the window Target CPU don't show the cpu as before. I was looking around all IDE options and I don´t know how to select it again.
Image as example: https://ibb.co/7pn7CsY
Any suggestion?
2,629 次查看
slanfys
Hello!
Can codewarrior update for free? I have a CD installer to install this IDE, but don't know if I could update it freely
2,619 次查看
vicentegomez
You can download a evaluation for 30 days, and depending on the license that you have you can or you can not update that license to Codewarrior 11.
But first, download and install the evaluation version and once you have installed you can go to your software license and support on your profile and check if you have the option to update your license
then go to software account
then check the options that you have to activate code warrior
Vicente
2,639 次查看
vicentegomez
I am not sure what is wrong with your project, but I have attached an empty project for the JN16 and PE in codewarrior 11, please update to codewarrior 11.
I hope this project will help you
Have a good day
