Need help on the DEMOJM lab 3
1,345 次查看
Richv
Hi all
I am having a bit of trouble getting lab 3 of the DEMOJM working.  I am using the daughterboard with MC9S08JM60 micro.  Labs 1 and 2 work fine.  When I get to Step 6 of Lab 3, I am stuck.  I get two errors entering step 6, and then I can't find the "erase and program menu".  Here is a screenshot of the two errors, and the window that appears at step 6.  Thanks in advance for your help!
Rich
1,046 次查看
Richv
The DEMOJM board now works thru lab 3.  I reloaded the disc (I must have incorrectly loaded it previously) and now everything works.
