Multi ATD Module Reading
Cn
Hello Forum I have a little question.
Does anyone have an idea how to read multiple channels of ATD module from M68MDEMO908GB60 because I want to read at the same time 3 analog signals..
If you have any code could you please post me in C code
peg
Senior Contributor IV
Hello Cn,
It's not rocket science.
You simply select the next channel with the SC register,then wait for the conversion to complete.
This may be by polling CCF of by interrupt.
Then you read the result and select the next channel and over and over.
