Map file
Map file
2,745 次查看
baonguyen
Dear everybody
What is the role of map file in CodeWarrior 5.1? Can we use it to see functions and variables called by our program while it's executing ?
Thanks a lot
1,407 次查看
CrasyCat
Specialist III
Hello
Within CodeWarrior the MAP file is just generated for documentation purpose.
It shows information about your application like actual code and data size, location and size of each object (variable, constant, function), dependency tree and so on.
This file is there as documentation purpose and is not used for debugging.
CrasyCat
