MOSI Low level
MOSI Low level
1,607件の閲覧回数
IlConte
I have S08AC32, I use the SPI uart, there is a possibility to have the MOSI signal at low level at the end of transmission ?
Stefano De Blasiis
1,513件の閲覧回数
tonyp
Senior Contributor II
I had the same problem when I chose to use the SPI for driving the sk68xx RGB LED, and the quick answer is you can't change this behavior of the SPI.
My solution was to invert the line and send inverted data.  It worked perfectly.
