MM908E625ACDWB Cyclone Pro
1,779 次查看
mnemonic
Hello!
I have some MM908E625ACDWB Chips here and I want do some Tests on it. Wich type is it? Is it a GP/JL/QY/JW type? Which Algorithm schould I use for programming?
I know this chip have a HC08 Core and should be programable witch Cyclone Pro.
Thank´s!
Ingo
1,336 次查看
mnemonic
Hello!
I found in datasheet that this chip should be the same as
MC68HC908EY16.
Ingo
