MC9S08PA..Code for Delay routine
869 次查看
mikee_
I am writing this piece of code in order to insert a delay in my execution cycle.
The code is the following:
DELAY:                STHX    DLY_A  ; (4)
LOOPOUT:          STX     DLY_B  ; (3)
LOOPIN:
                             DEC     DLY_B  ; (4)
                             BNE     LOOPIN ; (3)
                             DEC     DLY_A  ; (4)
                             BNE     LOOPOUT ;(3)
                             RTS
I am using code warrior 10.6
After starting the debug process. The communication with the micro-controller will stop after debugger will step in and is able to do few iterations .
PS: watchdog is deactivated.
Looks really weird.
Any help?
Any body has a better way to insert delay?
Many thanks
701 次查看
tonyp
Senior Contributor II
Hard to tell what's wrong without more complete code.  For example, where are DLY_A and DLY_B variables located?
BTW, here's a sample delay routine to give you an idea (but for ASM8 assembler)
