MC9S08DN60 Interrupt issue
vikassubramani
I am using a UART RX interrupt. The interrupt works fine but on the terminal it says syntax error i have attached the picture on how it looks like please let me know what changes i will have to make
ZhangJennie
Hi vikas,
please follow interrupt syntax like this:
interrupt 17 void   isr_routine_name(void)
    < your code ...>
this should fix the problem.
this answer is for you, if it helps, please click on "correct answer" button. thanks!
ZhangJun
ZhangJennie
Hi vikas,
    < your code ...>
ZhangJun
