Looking for the old Freescale Learning Accademy resources
4,413 次查看
damien_darhk
Hello, time ago i watch some educational videos from the Freescale website about how to create a c# GUI for DEMOJM, and if I remember right also some etpu relate videos. Now I can't find that videos in the NXP site; Are these resources avaiable?
4,311 次查看
vicentegomez
Yes, those were removed a long time ago, but I believe the followings link will help you
bitwok
and
How to include a bootloader for the MC9S08JM60 in your GUI - bitwok
Vicente
6 回复数
4,312 次查看
vicentegomez
bitwok
and
Vicente
4,311 次查看
damien_darhk
Thanks! Do you known if there are similar video resources for MCP ETPU learning?
4,311 次查看
vicentegomez
eTPU: Enhanced Time Processor Unit?
Please check
Designing an eTPU dual motor control solution | NXP
I am not sure if this is what you need.
4,311 次查看
damien_darhk
Thanks. I'm totaly new on etpu, never used MCP before, only HC08,HCS08 and HCS12, or Coldfire. I'm a bit confusing about the tool to use: in some AN I read that for MCU code is needed CW for MPC55xx/56xx 2.10, and if need to create ETPU code CW for ETPU, but in other is used S32. Also I can't download precompiled function from online etpu selector because I get an error occured. Cany anyone put me in the right direction please?
4,311 次查看
vicentegomez
First check the information on the community for the mpc5
MPC5xxx
On that community, my coworker will help you with your questions
regards
4,311 次查看
damien_darhk
Ok. Thanks.
