LIN Question
LIN Question
2,493件の閲覧回数
RChapman
This message contains an entire topic ported from a separate forum. The original message and all replies are in this single message. We have seeded this new forum with selected information that we expect will be of value to you as you search for answers to your questions.
Posted: Mon Nov 21, 2005 7:22 am
I know this question might not be directly related 2 a specific microcontroller. I am asking where can I buy LIN (Local Interconnect Network) cables?
Is there a hub or a multi-port connector that connects multiple slaves to the same LIN bus?
I need help as soon as possible....
Thanks 4 your time
Posted: Fri Nov 25, 2005 7:40 am
LIN bus is just a simple series bus , so what you need is just twisted cable.Each LIN device no matter master or slave either is series connected in one network, so hubs or muti-links are not needed.
Posted: Fri Nov 25, 2005 10:58 am
As Transcend said, you just need 3 common wires.
You need VDD which on cars would be typically 12-15V.
Vss = ground, and LIN wire.
You put everything in parallel on the same wires.
0 返答(返信)
