Kits for baremetal controllers
bakugo
Hi, I wanted to ask if there are any kits out there that come with a chip programmer and some peripherals to test assembly code on real hardware? I know that this can work on an esp, but I like the fact that it's the absolut minimum. Thanks!
luis_maravilla
Hello
The S08PT60-EVK, [MC9S08PT60] is a development hardware board that can help you with your application[S08PT60-EVK Product Information].
The onboard interfaces include an RGB LED, a 6-axis digital accelerometer and magnetometer, an ambient temperature sensor, two capacitive touch pads, a potentiometer, two user push-buttons, and IRDA transceiver. Also is compatible with the Arduino pin layout for expansions boards.
You can read more about the features in the main page: S08P MCUs Evaluation Kit | NXP Semiconductors
And there are available boards buying from the distributors. The software tool to use it is CodeWarrior for MCUs (Eclipse IDE) v11.1 available for windows 10/11.; in this tool you can test with assembly code.
Another board option is S08PB16-EVK Product Information | NXP Semiconductors, using CodeWarrior too, adding the correspondent service pack for S08PB or programming via debugger P&E Multilink FX or P&E Multilink
Best Regards
%3CLINGO-SUB%20id%3D%22lingo-sub-2410210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKits%20for%20baremetal%20controllers%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I%20wanted%20to%20ask%20if%20there%20are%20any%20kits%20out%20there%20that%20come%20with%20a%20chip%20programmer%20and%20some%20peripherals%20to%20test%20assembly%20code%20on%20real%20hardware%3F%20I%20know%20that%20this%20can%20work%20on%20an%20esp%2C%20but%20I%20like%20the%20fact%20that%20it's%20the%20absolut%20minimum.%20Thanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Kits%20for%20baremetal%20controllers%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%0A%3CP%3EThe%20S08PT60-EVK%2C%20%5BMC9S08PT60%5D%20is%20a%20development%20hardware%20board%20that%20can%20help%20you%20with%20your%20application%5B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FS08PT60-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES08PT60-EVK%20Product%20Information%3C%2FA%3E%5D.%3C%2FP%3E%0A%3CP%3EThe%20onboard%20interfaces%20include%20an%20RGB%20LED%2C%20a%206-axis%20digital%20accelerometer%20and%20magnetometer%2C%20an%20ambient%20temperature%20sensor%2C%20two%20capacitive%20touch%20pads%2C%20a%20potentiometer%2C%20two%20user%20push-buttons%2C%20and%20IRDA%20transceiver.%20Also%20is%20compatible%20with%20the%20Arduino%20pin%20layout%20for%20expansions%20boards.%3C%2FP%3E%0A%3CP%3EYou%20can%20read%20more%20about%20the%20features%20in%20the%20main%20page%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS08PT60-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES08P%20MCUs%20Evaluation%20Kit%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EAnd%20there%20are%20available%20boards%20buying%20from%20the%20distributors.%20The%20software%20tool%20to%20use%20it%20is%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DCWX-MCU-PROED-EX_11-1%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ECodeWarrior%20for%20MCUs%20(Eclipse%20IDE)%20v11.1%3C%2FA%3E%20available%20for%20windows%2010%2F11.%3B%20in%20this%20tool%20you%20can%20test%20with%20assembly%20code.%3C%2FP%3E%0A%3CP%3EAnother%20board%20option%20is%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fpart%2FS08PB16-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES08PB16-EVK%20Product%20Information%20%7C%20NXP%20Semiconductors%3C%2FA%3E%2C%20using%20CodeWarrior%20too%2C%20adding%20the%20correspondent%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DCWX-MCU-PROED-EX_11-1%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eservice%20pack%20for%20S08PB%3C%2FA%3E%20or%20programming%20via%20debugger%20P%26amp%3BE%20Multilink%20FX%20or%20P%26amp%3BE%20Multilink%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%3C%2FLINGO-BODY%3E
