How to use Watchdog in Beestack
1,487 次查看
JACKCHEN
Hi ,
I want to use watchdog in Wireless UART based on beestack.
But it is too quick to reset by the 2^18 cycles of the bus rate clock in beestack, is anyone had any experience of using watchdog in the beestack.
Thanks.
688 次查看
Denn
Hi Jack,
If COP watchdog is too fast, then you can have a SW watchdog wherein you determine the timeout period and after its successful completion, you insert illegal opcode which will initiate an "illegal opcode" reset.(WD timer is incremented everytime in the System clock ISR is executed say for every 1ms )
You can refer the thread which uses the above technique.
Denn.
