How to built reloctable software project in CW
3,500件の閲覧回数
Truk
I try it again with an other subject. Can anybody mail to me samples or descriptions how to do this, specially how I have to manage the variables all the INCLUDE files, which variables should be global end where should there be placed and so on, so that at debugging time all source-files are in the debugger for working with.
3 返答(返信)
2,009件の閲覧回数
Blackwolf
Hello Truk,
humm some relocatable examples could be found here (CW08 v5.0):
<your installation directory>\(CodeWarrior_Examples)\HC08\Assembly Examples\
- BlackWolf -
2,009件の閲覧回数
Sten
The easiest way to start with a new project is to use CW's New Project wizard; just answer all the questions it asks you and a empty, but working, project will be created for you into which you then can insert your source and include files. Regarding the global variables, see this thread http://forums.freescale.com/freescale/board/message?board.id=CWCOMM&message.id=1272&jump=true
2,009件の閲覧回数
Truk
My problem is, that I didn't understud the expanations which are for C-programming and not for assembler. If anyone has a small sample project which shows all the definitions it would be really very very helpfull for me!
