The BDM clock for the GT/GB is either BUSCLK (whatever you have that set to) or the 8MHz ICGLCLK. This is selected by the CLKSW bit in the BDMSCR register.
Regards David
Hi jjl3,
You only have to be accurate to "a few percent"
I know very detail about the DSP you mention but, the job gets done by 8 bit QT and JB processors running at 4MHz so I am sure you can get it done with your processor.
Why don't you have a look at the other BDM designs, I have listed them in this thread:
http://forums.freescale.com/freescale/board/message?board.id=16BITCOMM&message.id=1597
Regards David
Message Edited by peg on 2006-07-27 10:02 PM
