How can I record and read a value in the MC68HC908JL3CDW ROM when the resident routines do not work?
614 次查看
luissilva
I have a program in C and inside the routine "Void Main" I need to write and then read a value in ROM, then I update this value to save again in ROM. This value can not be lost in case of power failure. Resident routines did not work. Does anyone have any routine about this? Thank you.
0 回复数
