HCS08SL::Software Realization of SPI interface
3,775 次查看
Destiny
Dear Friends
         Did anybody tried for a software realisation of SPI interface?? Can anybody give me a hint how to proceed with it.
        The background is that we are having a interface of HCS08SL with a DAC (Analog device:AD5641) through an SPI (Master mode) connection. I need this software realisation of SPI since the one available with HCS08SL is already in use and cant be used for the DAC interface.
          Please help me!!
Priyant
4 回复数
2,195 次查看
bigmac
Specialist III
Hello Priyant,
Within the following thread is a software SPI written in C.
Mac
2,195 次查看
Destiny
Dear bigmac
  Thank you very much for your help... I will proceed with your code
thanks once again!!
Destiny
2,195 次查看
tonyp
Senior Contributor II
Here's one example (in assembly).  You'll need to modify for different polarity and phase settings.
2,195 次查看
Destiny
Dear Tonyp
  Thank you very much for your help... I will try this program and if any problem I encounter I will delinately contact you again...
thanking you again!!
Destiny
