HC908QB8 Tcyc question
Richard777
Hi, I'm planning use the HC908QB8 with external xtal of the 4.9152 Mhz, in this case what is the tcyc ( instruccion cycle time )
Thanks in advance.
Alban
Senior Contributor II
By default, the frequency of the bus is the XTAL divided by 4.
The intructions are executed based on the bus speed.
Cheers,
Alban.
Richard777
Thanks Alban :smileyhappy:
