HC908AZ32A HELP EEPROM locked out
RChapman
This message contains an entire topic ported from a separate forum. The original message and all replies are in this single message. We have seeded this new forum with selected information that we expect will be of value to you as you search for answers to your questions.
Posted: Mon Mar 21, 2005 5:30 pm
has anyone an idea how to unlock the EEPROM when EENVR (location $FE1C) is programmed to $00 ?
Posted: Tue Mar 22, 2005 7:27 am
You can't do it. The EEPROM security cannot be removed once armed.
Posted: Wed Jul 13, 2005 11:49 am
Not even when bulk-erasing the whole flash array? That should reset EENVR too, shouldn't it?
Posted: Fri Jul 29, 2005 2:27 pm
I don't think EENVR is stored in Flash, but in EEPROM.
The 908AZxxA has both and separated.
