HC05 assembly conversion to HC08
1,932 次查看
baddad
I'm helping to convert an old HC05 project to HC08 using CW v5.1.
This statement shows up as an invalid addressing mode:
LDA #"U"
I haven't been able to find the proper way to write this.
Any suggestions on what I can try?
Brian
854 次查看
RockyRoad
Brian -
I don't know why the double quotes (LDA  #"U") didn't work. But I tried with single quotes (LDA  #'U') and it worked correctly.
Interestly, this use of the double quotes for the string constant did work (and is another work around):
U:   EQU "U"
      LDA  #U
- Rocky
854 次查看
baddad
Thanks, I'll give it a try.
Seems to be a strange assembler response, because  LDA #"d" works...
Thanks again.
Brian
