Floating point division
2,211件の閲覧回数
woohoo
I am using a GT16A microcontroller and am having issues when dividing 2 numbers that would form a floating point number. There is no problem with addition, subtraction and multiplication.
For example, 20/8 gives me a value of 2.0 and not the expected 2.5
I have tried increasing the stack size and I still haven't managed to figure out what is causing the problem. Any ideas?
タグ(3)
2,011件の閲覧回数
kef
Specialist I
float f:
f = 20/8;
20 and 8 both are integers, division produces integer result, and then you request to convert integer 2 to float. To get 2.5 at least one of dividers has to be FP.
2,011件の閲覧回数
ZhangJennie
1. you need have floating lib support. when creates new project, choose floating library support for your project.
2. do like this:
float f;
f= (float)20/(float)8;
2,012件の閲覧回数
kef
Specialist I
float f:
f = 20/8;
