Flash programming MC9S08QG8
Mei
Dear Community
I wrote an assembler program to store data in the flash of MC9S08QG8.
It still has errors. The program allows one byte to be saved
in a program loop in BDM debug mode,
but not several bytes continuously.
The required NOPs at the end of the programming loop are also not OK.
Can you help me?
Mei
Now I have implemented my Flash program for writing bytes and
deleting byte blocks in assembly code.
The community helped me with this, but I don't know how to
give kudos to the answer authors.
Another interesting observation when using the Flash routine: When I test the routine with a chip that has been used for a long time,
it happens that some bytes in the deleted block are not deleted.
If I write and delete in a higher, less used program area,
this doesn't happen.
Thank you to the community
Next time I would like to ask my questions about transferring
the measured values ​​to a PC.
With best regards
Gerd
