Flash Programming for MC9RS08KA2
1,895 次查看
seiji
I want to use 2 bytes flash of MC9RS08KA2 for config, but I see that:
Flash memory cannot be programmed or erased by software code executed from flash and device does not include on-chip charge pump circuitry, external VPP is required for program and erase operations.
I would like to know if I put external Vpp and run the flash programming procedure from RAM. Can I program flash? If possible, someone have an example for this.
Thanks.
1,159 次查看
Alban
Senior Contributor II
Hello & Welcome Seiji,
You don't only need Vpp outside but also a very special circuitry.
I don't have the details of the circuitry itself but you need to respect timings with Vpp.
Please look at the datasheet that surely explains better than I am now.
Cheers,
Alban.
