File .CRT
File .CRT
2,289件の閲覧回数
FabioPdM
I'm trying to create a .CRT file in Code Warrior Classic from a .S19 file.
Is it possible or this standard .CRT is not public and I need some specific SW and some parameters?
Is it possible with Code Warrior Ecilpse?
What are the basic differences in .S19 and .CRT standars to flash a MC9S08AW32 ?
Can I use both for the same purpose ?
2,259件の閲覧回数
Itzzamna_Supp
When compiling, S19 is generated and remains in the FLASH folder, the SRecord file type is saved there in S19, where you will find the CRT.
