Fault found on 9S08SH16 part
1,488件の閲覧回数
Goz
Hi everyone,
I thought I would post this in case anyone else, like me, has wasted a day on a this problem and hasn't found a possible cause/solution.
There is an issue on the 9S08SH16 parts, but I don't know if this is related to a batch only. If you poll the TPM1 Channel 1 interrupt flag (TPM1C1SC_CH1F) for a number of cycles, the MCU will suddenly start to change its system frequency and will jump to a random memory address location.
I have tested this by polling Channel 0 on TPM1 and the TPM2 channels and the device is stable when doing so. I also tested this on all of the parts I have (13 in total) on our prototypes and they all behave the same. I have also sent this to Freescale support for them to look into.
I hope this may help someone else out there who has been pulling their hair out wondering what's going on.
1,020件の閲覧回数
JimDon
Senior Contributor III
If this is the case, you should submit a service request.
If possible, create a test program that only has this code in it.
You may find there is a work around.
