FXTH870912 - TPMS weak signal problem
shivamprajapati
Hey there! I m working on FXTH870912 TPMS but on transferring data through RF module, the signal is so weak (about -10 dbm). Is there any way to increase the signal strength? or should i have to make the receiver antenna more sensitive to get the signal at bigger range of distances?
anthonyhhfu
Hi Shivam,
did you get problem solved?
Anthony
