Extra byte for SCi: on MC13213
2,009件の閲覧回数
lak
I observed on one of our MC13213 boards that the SCI outputs one extra byte(0x00) whenever I shut off the transmitter,by clearing the TE bit from 1 to 0, after transmitting all the data.
Surprisingly, the same behaviour is not seen in other evaluation boards which also use the same chip MC13213.
This I observed straight on the micro TXD1 pin to isolate other circuit related scenarios.
Is it any chipset related issue ? or anybody has come across this kind?
with regards,
Lak
1,307件の閲覧回数
peg
Senior Contributor IV
Hi lak,
As your question seems extremely similar to this current one:
 how about you just join in there and save duplicating the responses.
