Example code for the MC9S08PT32VLH
2,700 次查看
BPR
Iam looking for an Example code for the MC9S08PT32VLH board but can only find assembly code examples in Code Warrior. Where can I find the example codes in c, particularly I want UART related code to check serial logs.
2,678 次查看
BPR
Hi RaRo,
I don't have that dev board with me. I have a custom board which has MC9S08PT32VLH which is of 32KB Flash Memory.
If you have any idea about examples (in C) specifically reated to MC9S08PT32VLH kindly let me know.
2,623 次查看
RaRo
Hello @BPR,
Unfortunately, there is not an example in C for the MC9S08PT32VLH about how to use UART. Nonetheless, you could use the information above or the following link as a reference to your implementation.
We apologize for any inconvenient this may cause you.
Best regards, Raul.
