Erasing a HC908 MCU unit
4,410 次查看
RChapman
This message contains an entire topic ported from a separate forum. The original message and all replies are in this single message. We have seeded this new forum with selected information that we expect will be of value to you as you search for answers to your questions.
Posted: Fri Dec 31, 2004 11:32 pm
I lost the security codes and the "ignore security" option in the hiwave.exe tool from PEDMicro seems no to work. Any one knows how can erase the unit ??
Posted: Tue Jan 04, 2005 9:48 am
Hi!
If the ignore option doesn't give you access to monitor mode, it is rather a communication problem with the micro.
Check the baudrate and tell which stages are YES and NO at the bottom of P&E comms window.
The complete erasure of the micro doesn't need the key.
0 回复数
