Doubt with interrupts with MC9s08sh8
990件の閲覧回数
glaa91
Hi, i'm trying to make a program that when i put VCC on one pin of the PortA, the program jump to an Interrupt and turns on a Led on Port B.
The problem is that i can't configure the interrups, and i can't find my error, can anyone help me?? Thanks
it's a simply test program, here it's:
; Include derivative-specific definitions
            INCLUDE 'derivative.inc'
; export symbols
            XDEF _Startup
            ABSENTRY _Startup
; variable/data section
            ORG    RAMStart         ; Insert your data definition here
            ORG    ROMStart
_Startup:
       LDA SOPT1 ;Deshabilita COP
       AND #%00111111
       STA SOPT1
       LDHX #RAMEnd+1 ; initialize the stack pointer
       TXS
       MOV #%00000001,PTBDD
       MOV #%00000000,PTCDD
       MOV #%00000000,PTAES ;SLEW RATE
       MOV #%00000000,PTADD ;IN/OUT
       MOV #%00111111,PTAPE ;PULL-UP/PULL-DOWN
       MOV #%00001111,PTASC ;INTERRUP STATUS AND CONTROL
       MOV #%00001111,PTAPS ;HABILITAR/DES INTERRUPCIONES
       ;MOV #%00001111,PTAES ;
       CLI
INICIO:
       BCLR 0,PTBD
ini
       JMP ini
;* spurious - Spurious Interrupt Service Routine.             *
;*             (unwanted interrupt)                           *
interrup:
            NOP
            SEI
            BSET 0,PTBD
            CLI
            RTI
spurious: ; placed here so that security value
            NOP ; does not change all the time.
       RTI
;*                 Interrupt Vectors                          *
  ORG $FFD6
  DC.W interrup
  ORG $FFFA
  DC.W  spurious ;
  DC.W  spurious ; SWI
  DC.W  _Startup ; Reset
2 返答(返信)
727件の閲覧回数
bigmac
Specialist III
There are two problems that I can see -
  1. The interrupt edge select register PTAES would seem to have the incorrect setting for what you require.  This is not the slew rate register, as your comment indicates!  Your settings will give falling edge interrupt operation, with pullups enabled, consistent with a grounded switch contact.
  2. The interrupt will need to be acknowledged within your ISR code, to clear the interrupt flag.  Otherwise repeated interrupts will occur.  Additionally, unless you have a specific need for combined edge and level sensitivity for the interrupt, I might suggest that you set for edge sensitive interrupts only.  Level sensitive interrupts will potentially cause multiple interrupts while the input level remains active.
interrup:
            NOP             ; Unnecessary instruction
            SEI             ; Unnecessary instruction
            MOV  #%00000110 ; Acknowledge interrupt
            BSET 0,PTBD
            CLI             ; Unnecessary instruction
            RTI
Mac
727件の閲覧回数
glaa91
Hi, thanks you very much for the answer, but i'm still having problems... I can not make that the program works, it is never jumping to the interrupt, can you give me a little more help?
Here is the modified code:
_Startup:
            AND #%00111111
            STA SOPT1
            TXS
       ;MOV #%00001111,PTAES      ;INTERRUP EDGE
       ;MOV #%00011111,PTASE      ;SLEW RATE
       MOV #%00001111,PTAPE      ;PULL-UP/PULL-DOWN
       MOV #%00000110,PTASC      ;INTERRUP STATUS AND CONTROL
       MOV #%00001111,PTAPS      ; Enable/disable interrups
       CLI
INICIO:
       BCLR 0,PTBD
ini
       JMP ini
interrup:
       ;NOP
       ;SEI
       MOV  #%00000110,PTASC ; Acknowledge interrupt
       BSET 0,PTBD
       ;CLI
       ;RTI
  RTI
  ORG $FFD6
  DC.W interrup
  ORG $FFFA
  DC.W  spurious ;
  DC.W  spurious ; SWI
Gaston.
