Device support of TBDML
RChapman
This message contains an entire topic ported from a separate forum. The original message and all replies are in this single message. We have seeded this new forum with selected information that we expect will be of value to you as you search for answers to your questions.
Posted: Fri Nov 18, 2005 10:50 am
Hi Guys,
can someone direct me to some info on the full device list of supported devices for the TBDML board?
Can I use it to program HC08 series, like as an example, the MC68HC908QT4?
best regards
Posted: Fri Nov 18, 2005 11:39 am
Today on HCS12 devices are supported, with the exception of NE64. Modes are being made at the moment and there will be a new release in December/Jan to support S08.
HC08 will not be supported as it does not have BDM support.
Posted: Fri Nov 18, 2005 11:41 am
Oops, also all HCS12X versions are supported.
Posted: Fri Nov 18, 2005 2:13 pm
For HC08 you don't need all that hardware to program.
A serial port is enough for you... With an MAX232 to translate voltage from 5V on the MCU to 12V on RS232.
Cheers,
