Connector or Cable for USBSPYDER08
2,602 次查看
Dakota
Good Morning,
I searched this forum for the answer to my question, but could not find a relevant post.
Does anyone know where to purchase either a polarized, 6 contact IDC connector that will mate to the USBSPYDER08, or a ribbon cable connector with 6 contacts?  The smallest connector that I can find has 10 contacts, and it will not fit in the socket.
I think that I could probably modify a 10 contact connector, or connect to the vertical 6 pin header, but there should be a cleaner way to use the BDM port.
Thank you.
998 次查看
baddad
The 6-pin IDC connectors are hard to find.
Witztronics sells a 12", 6-pin IDC cable on their web site:
Maybe that will help.
BadDad
998 次查看
Dakota
Good Morning,
Thank you for the information.  This will definitely get me started without having to cut and modify existing connectors.
In Fall 2007, I am teaching a control systems class, and it would be nice to have some 6 contact ribbon connectors (not the pre-built cable assemblies), but the cable assemblies will work if no connectors can be found by that time.
