Code Warrier Assemblier source code compatability
BobMac
Hi Everybody;
 I have got some assemblier source code we wrote for use in P&E WinIde and wanted to use it in Code Warrier. Needless to say, the C.W. complains about everything! is there a "style sheet" or manual for the C.W. Asm08 or whatever it's called. ;o)
Best regards, Bob
bigmac
Specialist III
Hello Bob,
The following thread may be of interest, to help you reduce some of the CW assembly errors.
Within your CW installation, should be the following file -
...\Help\PDF\Assembler_HC08.pdf
Mac
BobMac
Thanks for the info Mr. Big;
 I guess what I was looking for is an app note or data sheet entitled "Freescale CodeWarrier Assembly source code style sheet for Dummies and (or) Doofuses"
Best regards, Bob
